Clermont, FL, USA
I am looking for an aftermarket carberator for a 2002 Yamaha TTR 90. I see a lot of carbs on eBay for under $50. Can anyone help me find one that will fit my sons bike? They are like $250 for the actual OEM carb and looking to save some money.
The Japanese made the stock carb easy to clean and replace rubber and brass parts.
If you must get the ebay carb please know they are jetted wrong, one size fits all is their plan, but jetting matters.
If you get the ebay carb you must change the jetting to match what you had stock with your original carb.
Example, you have 15 pilot jet, but they might put a 20 on the ebay carb and the 20 would make that bike to rich.
Double check the sizes of the actual jets match and the china carb can work fine.
For the money you could buy a couple of different size carbs, with the same flange width, and give each one a try. On a 70cc pit bike, I had good luck with an 18mm carb. Would not go bigger than a 20mm for a stock TTR 90.
Post a reply to: TTR 90 carberator
