Thurmont, MD, USA
2/16/2020 6:43am
The bearing on the chain side of my swingarm is not as tight as it should be. I replaced the bearings and put maybe 10 hours on them and the press fit was great. I just pressed them out because I am having it polished and reanodized and chain side came out way to easy. I took the bearing from the other side thinking it could be the bearing and was able to press it in by hand. It’s tight enough I can’t spin the race by hand but it’s definitely not as tight as it should be. Is there any permanent fix for this. I know I can use press fit repair but how long does that stuff work? I don’t want to spend time and money polishing and anodizing it if it only has a little life left. Also does anyone know what causes this? I don’t see any cracks and nothing looks bent. Like I said I replaced them about 10 hours ago greased them really good and used a press when I did it. Any help on a permanent repair would be helpful. I have no experience with the press fit repair stuff so if anyone has used it and got years of use with it please let me know. Thanks
It can come out fairly easy and not have any side to side play. The bearing is sandwiched in there so axial movement isnt really a concern.
You dont need go buy a $900 swingarm. Having that bore welded and remachined wont cost $900.
Post a reply to: Swingarm repair help!
