Rm125 help
wilh72
Mentone, CA, USA
Edited Date/Time 2/11/2019 11:10am
Anyone know the stock sprocket sizes front and rear for a 03rm125 and also what would you guys suggest to run for a little more low end? Currently running 13/49 which was how I bought it.
Rotaholic
NZ
2/10/2019 12:25pm
Try running 13/51 that should make it a lot snappier
wilh72
Mentone, CA, USA
2/10/2019 1:06pm
Thanks! Going to pick up a sprocket and chain today. Yesterday was my first time riding it and the chain and sprocket were in decent shape so I figured I’d try that gearing before buying new, but it definitely needs to be done.
wilh72
Mentone, CA, USA
2/10/2019 6:35pm
Picked up a clutch kit as wel today was wondering if you knew what the torque specs are for the springs?
Falcon
Menifee, CA, USA
2/12/2019 3:55pm
For future reference, 12/49 gearing is stock. 13/51 will be slightly taller.
ktm-5
Ravenna, MI, USA
2/12/2019 4:29pm
I never torque them just tighten them and the spring pressure helps also
2/18/2019 8:00pm
87 inch pounds. Make sure you torque them in a star pattern so the pressure plate sits evenly. Always torque engine parts, you're smart to ask that and not just go by feel.
BR8ES
Bennett, CO, USA
2/19/2019 11:14am
If you are going to use a torque wrench, please use an 1/4 inch drive.
SBD
San Diego, CA, USA
2/19/2019 12:13pm
Why not 3/8 drive ? Im curious.
BR8ES
Bennett, CO, USA
2/19/2019 12:45pm
Mainly because the torque spec is very low for the majority of 3/8 drives. Ideally you want middle of the road and majority of dirt bike fasteners are pretty low. There have been many bolts snapped with 3/8 in the low range. If that is the only wrench available, go easy. I rarely use a torque wrench on those clutch bolts as all you need to do is bottom the bolt and no more. My experience anyway.
SBD
San Diego, CA, USA
2/19/2019 12:51pm
BR8ES wrote:
Mainly because the torque spec is very low for the majority of 3/8 drives. Ideally you want middle of the road and majority of dirt bike...
Makes sense for the clutch spring bolts. Yes I have snapped one just snugging it up.
Post a reply to: Rm125 help
