New clutch not working right
z71will
Pinson, AL US
Edited Date/Time 9/30/2019 4:26pm
In the process of building this 2001 cr125. I installed a brand new clutch kit. I got the engine back on the frame and everything hooked up. When I pull the clutch lever in, it's really hard to squeeze. I use some heavy duty grippers to work out my grip strength with (starting at 100 pounds grip force going up to around 350 pounds) and it feels as hard as the 100 pound gripper. I know it should not feel this hard. It should feel smooth as butter. And yes, I have a brand new clutch cable installed already!! Also when I pull it in and I go to see if the transmission turns it won't. So basically the clutch is doing nothing. So my problems are: 1) clutch is extremely hard to squeeze and 2) clutch is not working at all
Acidreamer
Mansfield, OH US
11/16/2017 11:29am
Ive had luck in the past by replacing that actuator arm that sticks out of the case. For whatever reason it corrodes or wears out or somethig and becomes hard to pull.
It could be an adjustment thing or springs that are too stiff. Also it becomes easier when the bike is running and the clutch has oil all over and inbetween the plates. If its dry it wouldnt surprise me one bit that its stiff.
z71will
Pinson, AL US
11/16/2017 11:41am
Acidreamer wrote:
Ive had luck in the past by replacing that actuator arm that sticks out of the case. For whatever reason it corrodes or wears out or...
When the clutch wasn't in the actuator arm moved just fine. Also the clutch plates were soaked in oil a few days before installed.
z71will
Pinson, AL US
11/16/2017 11:50am Edited Date/Time 11/16/2017 11:50am
I pulled the stator cover off and the actuator arm is moving like it should yet the clutch is still not working and hard to move?
z71will
Pinson, AL US
11/16/2017 12:16pm
Here's a video. I took the cover off and here's what happens when I squeeze the clutch. Does everything look normal to y'all?
z71will
Pinson, AL US
11/16/2017 12:17pm
And here's a photo of it
Micahdogg
11/16/2017 12:23pm
If these are new springs, and you have no idea how they should feel, then the springs are probably really tight. Toss in some old springs if you have them and see if that gives you the "feel" that you think it should have.
Also, I don't think that pulling the clutch lever on a brand new, oil soaked clutch kit, with no run time is going to allow you to just "spin" the transmission if its in gear. When you pull the lever, you probably still have a lump of clutch plates all stuck together. You really need the engine vibration, heat, spinning crankshaft, etc... to help in disengaging the power transfer.
z71will
Pinson, AL US
11/16/2017 3:00pm
Micahdogg wrote:
If these are new springs, and you have no idea how they should feel, then the springs are probably really tight. Toss in some old springs...
Ok but does it look like everything is leaned to one direction to you? Look at the center piece. Is that normal?
Ti
PA US
11/16/2017 3:45pm
No... that is not normal, you need to disassemble that clutch pack. ASAP. Post pics of the clutch pieces and HOPE Paw Paw is around!
z71will
Pinson, AL US
11/16/2017 3:53pm
I noticed when I put the inner clutch hub in that one side seemed to poke out a little more. Maybe that's causing the problem?
z71will
Pinson, AL US
11/16/2017 3:54pm
How would I know if it's straight or what to replace?
Ti
PA US
11/16/2017 4:13pm
Here is the schematic. For your clutch to be off center like that... you either do not have all the parts installed correctly, or a part or parts are worn out. Your engine would vibrate a LOT if you ran it, as in the picture. Looks like the clutch basket is worn??? There is a video on youtube. search: Dirt bike/motorcycle clutch rebuild/install Cr125.
z71will
Pinson, AL US
11/16/2017 4:24pm
Ti wrote:
[img]https://p.vitalmx.com/photos/forums/2017/11/16/225525/s1200_image.jpg[/img] Here is the schematic. For your clutch to be off center like that... you either do not have all the parts installed correctly, or a...
There are no parts missing and everything is in correct order. And my outer clutch basket? It looks good to me.
Ti
PA US
11/16/2017 5:01pm
I am on a phone, so maybe it is just the angle of the picture. When looking straight at your clutch, the springs and bolts should be centered and your plate/ clutch lifter [part 9] needs to be centered on the pressure plate. just noticed at the 2 o'clock position of the basket that the tab has a chip out of it... so I thought maybe you have a excessively grooved clutch basket and the fiber plates were getting stuck in the grooves thus making the clutch pull extreme. Anyway if there are no parts missing and assembled correctly and the parts are not worn... only other thing is make sure the new clutch cable is not hung up anywhere.
Benton, LA US
11/16/2017 5:11pm
You said new clutch...
Then why is there wear showing on the top fiber plates fingers?
Is the clutch basket notched? If so and new fibers are installed then the fibers no longer align with the notches in the basket and thus they will catch on the groves.
RE: Center bearing.... Yes it floats and can be off center.
I suspect worn basket and may be even inner hub.
z71will
Pinson, AL US
11/16/2017 5:17pm
Paw Paw wrote:
You said new clutch... Then why is there wear showing on the top fiber plates fingers? Is the clutch basket notched? If so and new fibers...
The basket does have a small chip but I don't think it'll hurt anything? Also the plates aren't worn they just look like that. So the inner hub would cause this?
z71will
Pinson, AL US
11/16/2017 5:31pm
My clutch is going in normally based on the videos I've watched, so if it's moving right then why would it not work?
z71will
Pinson, AL US
11/16/2017 7:46pm
So how will I know if my basket or inner hub needs to be replaced? I'm pulling it out tomorrow. What should I look for?
dirtmike86
Grand Terrace, CA US
11/16/2017 11:36pm Edited Date/Time 11/16/2017 11:37pm
It shouldnt have any up down, side to side movement. Or the obvious loose or missing needles in the bearings.
Benton, LA US
11/16/2017 11:56pm
You are looking for notches or rough spots and also make sure each fiber plate moves freely on the splines of the inner hub and the openings of the outer hub. Also be sure the basket and inner hub spin freely.
z71will
Pinson, AL US
11/17/2017 9:47am
I not sure if it's supposed to have these grooves or not. Does this look good to y'all?
z71will
Pinson, AL US
11/17/2017 10:01am
Nevermind I did some research and this seems to be the cause of my problem. So I either need to grind it down or buy a new one, and right now I can't afford a new one so grinding will do.
z71will
Pinson, AL US
11/17/2017 10:04am
Now onto the inner hub. It has notches as well but they're barely noticeable. Should I replace it? Also how would I know if my inner hub is uneven? I think it might be causing the leaning of everything as shown in the photo.
Acidreamer
Mansfield, OH US
11/17/2017 11:17am
Id replace both. The width of the slots on the basket are critical for the clutch to work right. Also if you dont do it straight youll be in the same boat youre in. You can get used baskets in good condition for cheap on ebay. Hell even some billet aftermarket ones are only $250.
z71will
Pinson, AL US
11/17/2017 11:48am
Acidreamer wrote:
Id replace both. The width of the slots on the basket are critical for the clutch to work right. Also if you dont do it straight...
Only $250??
Benton, LA US
11/17/2017 11:54am
The basket groves are not normal and are causing the problem as the fiber plates are hanging on them.
There is no way to get the grind even on all the basket openings for the fiber plates. This will result in some very un even side loads on the fibers and they will break and that could cause many more problems and damage.
FYI: The last photo shows that some one has already tried to grind or file these same places.
Replace both inner hub and basket before you cause even greater damage or get hurt while riding.
Acidreamer
Mansfield, OH US
11/17/2017 12:35pm
z71will wrote:
Only $250??
You wanna replace 10 oem ones or 1 aftermarket one?
z71will
Pinson, AL US
11/17/2017 12:40pm
I bought a new inner clutch hub but I have $0 more to spend on this bike
pmshortt2
VA US
1/22/2018 12:21pm
Any update on this? I had a similar issue. My clutch basket was worse than yours and my hub was also not too good. Ordered both last night along with new plates and new shift pawl springs and a couple other small things for the shift mechanism.
My bike got to where I had 1st, 2nd and neutral but couldn’t go up to 3rd. Found broken friction plate fragments when I pulled the side of the case cover off. Excited to get it going again after I get my new clutch and shift components in. It’s a 97 yz125
Uk2quick
Manchester GB
9/30/2019 4:25pm
Pls don't try cut corners with these things the bikes deserve looking after.... There not hard to look after...
Post a reply to: New clutch not working right
