NGK plug alternative
Insider347
Raleigh, NC, USA
I have a 2014 ktm 150sx and was wondering if I could use a cheaper plug. I change them often and never foul but the br9ecmvx is $25. Can I use the BR9ECMIX that is around $12. I know the tip on theach stock plug is supposed to resist vibration and breaking off but thought I would ask. Thank guys.
Paw Paw 271
Benton, LA, USA
11/23/2016 4:11pm
Go to sparkplugs.com and do a comparison doe the real skinny.
nascarnate326
Charlotte, MI, USA
11/23/2016 5:30pm
holy shit, $25 for a two stroke plug?
I thought that was expensive for a 40 hour 4 stroke plug. lol
BobPA
11/23/2016 9:45pm Edited Date/Time 11/23/2016 9:58pm
You can run a standard br9ecm which can be had for $10 or so. The ECM is just a more compact version of the standard br9es, which I believe would work depending on your available space...and there is also a br9eg available...
Some old bastard once said "buy cheap plugs and expensive beer"
I've tried many different plugs through the years and never saw much of a difference between a standard ES to the iridium. Between bikes, snowmobiles, stand up and even my old mans drag outboard we have tried our fair share.
I run a br8ecm in my 250 Kawasaki because of fuel tank clearance, if it were not for that I would be running the standard $2 ES. Been running cheapo's in my 125....came with an iridium in it, used it to tune because it already had some color as a base. Been running a cheapo ever since with no issues.
Post a reply to: NGK plug alternative
