Measuring triple clamp offset
Edited Date/Time 8/22/2021 1:31pm
Is this an accurate measurement of triple clamp offset?
1) Measure the stem diameter = 30mm. We need the radius = 15mm
2) Distance between front edge of fork tube and stem = 40.0mm
Offset = 40.0 - 20.5 (radius of fork tube) + 15 = 34.5mm (35mm nominal)
Luxon MX
San Diego, CA, USA
8/22/2021 7:30am
It's not a bad way to get close. If you can stick the fork tubes in there, it will give you a positive stop for your rule to remove one source of error. Measure to the nearest tenth of a mm and try to use the same (light) pressure on the caliper all the time. Measure a few times and if you're getting consistent measurements then call it good.
Also, most things are designed with nominal dimensions, so if your math ends up with an odd number, it' probably the closest nominal half millimeter. So:
(29.9 / 2) + 40.1 - (41.0 / 2) = 34.55, so 34.5mm offset
8/22/2021 9:18am
Luxon MX wrote:
It's not a bad way to get close. If you can stick the fork tubes in there, it will give you a positive stop for your...
Can clarify the formula? The example I found in the op has
A - B + C = offset (nominal)
A = Distance between front edge of fork tube and stem
B = Radius of fork tube
C = ??
Resulting in:
40.0 - 20.5 + 15 = 34.5mm
Your example has
Can you clarify what each number represents?
Luxon MX
San Diego, CA, USA
8/22/2021 1:29pm Edited Date/Time 8/22/2021 1:31pm
Can clarify the formula? The example I found in the op has A - B + C = offset (nominal) A = Distance between front edge...
C = ??
Resulting in:
Your example has
as the photos show, it's:
(Stem_Diameter / 2) + Stem_Edge_to_Fork_Tube_Edge - (Fork_Tube_Diameter / 2) = Offset
Post a reply to: Measuring triple clamp offset
