Kxf450 problems
Edited Date/Time 4/13/2021 1:16pm
Hi all new to this forum
My problem is I have kxf450 2014 model won’t start from a kick but will start if I connect a 12v battery any ideas ?? Thanks
kb228
Mansfield, OH, USA
4/13/2021 1:20pm
Capacitor
4/13/2021 1:44pm
Just had the captor sorted / West Country windings also tried another condensor still same problem
Paw Paw 271
Benton, LA, USA
4/13/2021 2:23pm Edited Date/Time 4/13/2021 2:25pm
So, did the bike have a 12 volt battery new? I did not think that year had a battery.
Stator not creating the 12 volts?
4/13/2021 2:58pm
Sorry it was my stator I had sorted , as it was earthing out , had it rewound and sorted , the bike never came with a battery from factory , just has a condensor/ capictor and I’ve also tried one off another bike / and tried mine on his and is working fine on his bike !!!
Paul_Pitzonka
Grand Terrace, CA, USA
4/13/2021 5:09pm
If you had a stator failure I’d inspect the regulator/ rectifier to make sure its operating correctly...
RGaede
Albuquerque, NM, USA
4/13/2021 5:40pm
So, did the bike have a 12 volt battery new? I did not think that year had a battery. Stator not creating the 12 volts? Paw...
Kawasaki and Suzuki have a harness that plugs any motorcycle 12v battery into the bike in place of the capacitor. It is used for connecting the diagnostic software up to the bike. I have found it useful for diagnosing stators as well. Had an rmz that felt like it was running out of fuel, but when connected to the battery ran fine. Stator had eaten a cam cap dowel.
Radfonz
4/13/2021 8:49pm
fuel pump
4/13/2021 11:50pm
Stator was damaged but all sorted now !! And still won’t start , 12v seem to prime the fuel pump up , once bike starts it runs great just needs that battery to start it when it shouldn’t
4/14/2021 1:50pm
Can anyone explain how a flywheel would be touching the stator ?theres No movement in flywheel
Paw Paw 271
Benton, LA, USA
4/14/2021 4:09pm
Bad crank bearing?
4/19/2021 1:28pm
Still not got the bottom of this !!
Post a reply to: Kxf450 problems
