Oak Harbor, OH, USA
12/26/2019 5:59am
I bought a bike brought it home had low coolant and low oil . Did oil change put coolant in it and started second kick. The next day it i went to start it and it would not start. It had good compression and it acted like it wanted to start at some point but then nothing. This is the filther that i pulled out
I would drain the oil and refill with the measured amount. That way you rule out to much oil.
You just said you didn't measure it and now you did?
In this case always check the valves. Its good to do frequently on a 250 anyway.
Imo check the plug for spark.
Post a reply to: Kx250f 2019 problems
