Mansfield, OH, USA
So just as soon as i got this thing fixed, i rode it in the mud and washed it, and now its hard to start. Ruled out valve clearance as its the same as last weekend when it started and ran fine. Also i can hook the bike up to a battery and it starts just fine. If i run it off the capacitor it takes 50+ kicks to start. The bike kept the battery voltage at 13.5 or so so im assuming the stator is fine. While testing the capacitor resistence, i noticed my meter would show OL as the resistence climbed up. The resistence does go above the 5k ohms the manual specs, but the OL reading that flashes concerns me. Im not sure if thats normal or if its indeed shorting out.
As of now the bike does get fuel, spark(even with the capacitor hooked up), and air. I noticed the voltage on the capacitor wont go above 3 when kicking. It just drops back to zero. Stator ohms out within spec. capacitor doesnt seem to hold a charge. If i connect the capacitor in series with the battery, the bike will not run. Any insight or experience with this?
Have you load tested the battery?
I was thinking the battery provided all the juice, not that it was completing the circuit
I guess what ill do is just go ahead and try replacing it.
Other than that, if you get the bike going it runs as long as you want it to and runs great. Maybe it is a starting capacitor?
I tested the capacitor before i left for work this morning. If i set my multimeter to ohms, the capacitor SHOULD start at zero and climb towards infinity. Of course thats not the case. It starts at 2.06 mega ohms and then immediately my meter goes to OL. For reference, my service manual says it should be over 5k ohms after 2 minuets. That tells me somethings wrong. I have a new one on order.
Post a reply to: KX450 Problem
