KX250f spark issue after wash
cdziekan
Austin, TX, USA
my 2011 KX250f misfires like crazy after washing it, definitely an spark/electrical issue. I didn’t power wash it, Plugged the exhaust too. And i’ve already cleaned/ blew out most electrical connections with air. Bike ran perfectly at the track earlier. Here’s a video of how it runs, it smokes a ton too which you cant see really in the video and smells like unburnt gas https://youtu.be/T0vNBR_dXKg
Paw Paw 271
Benton, LA, USA
3/30/2021 6:06am
Take all electrical connections and connections apart . Then clean them and lubricate them with dielectric grease.
cdziekan
Austin, TX, USA
3/30/2021 7:06am
We did this to almost every connection we could easily get to, but we didn't grease them. Also tried other things like disconnecting the kill switch incase it was wet and made sure the airbox was dry. nothing worked Sad
40acres
Houston, TX, USA
3/30/2021 7:34am
cdziekan wrote:
We did this to almost every connection we could easily get to, but we didn't grease them. Also tried other things like disconnecting the kill switch...
Get to the rest of the connections. Add dielectric grease to each one.
Paw Paw 271
Benton, LA, USA
3/30/2021 3:25pm Edited Date/Time 3/30/2021 3:27pm
X2 plus do this on every wire mount to the frame as well. All it take is one bad, dirty, rusted corroded or wet connection to cause these issues. ( even the ones that are not easy to get to.) Use spray Super Clean or spray electrical contact cleaner on each prior to adding the grease. The video seems to indicate that the spark plug is wet or the connector to the plug is bad. Check for a bright Blue spark at the plug.
PawPaw
Post a reply to: KX250f spark issue after wash
