Ravenna, MI, USA
12/4/2017 5:38pm
It's the wire that goes for the starter button but is part of the whole wire harness, is there a way to fix this or am I stuck buying a whole new harness? There has to be a way to fix it,any way to get connector put of plastic?
As a final resort, you can just use a male/female connector that runs outside that wire harness. Wrap it with some electrical tape and forget about it.
https://www.ebay.com/itm/3-Circuit-Connector-Set-of-3-Complete-molex-wi…
The metal part is called pin connectors.
https://www.ebay.com/itm/US-Stock-100pcs-Female-Pin-Dupont-Connector-Go…
I'd practice making a couple connectors before you take a stab on the connector on the bike.
Hey mate how did you get it out?
Not sure he'll see it as this is an old thread but I just did a bunch of those on my KTM 640. Those are Molex connectors. I'm guessing he managed to sorta rip it out. You need a special little pin disconnect tool that slips over the outside of the connector as it sits in the plug. This will push those barbs in and allow you to pull out the connector. It can be a pain. Sometimes the cheap pin removal tools work but I ended up getting a decent one that made the job much easier. The metal connectors you can get online or a good electrical shop will have them. To crimp them on, if you are real careful, you could do with some needle nose pliers of you can get a good, proper crimping tool.
This guy makes de-pinning seem easy. I found that it took a bit to get the hang of:
https://www.youtube.com/watch?v=H47vfMNxX_M
Another good one:
https://www.youtube.com/watch?v=kKkqXKfNuRQ
Post a reply to: Broken wire fix??
