AER Pressure
TC125
Have had my '17 TC125 for a few months now and really haven't played with the forks much, have been running them at 120psi for my 165lb weight but have been fighting the rear shock a bit. Dropped my forks to 117psi and noticed a lot more movement when out on the track - and the rear seems to be better in the acceleration chop that has been a problem. Not sure if this is all in my head but going to run it this way for a while and see how it goes. Has anyone else saw similar results? Does any of this make any sense??
Spudnut
7/30/2020 5:25am
You have to Remember to adjust your shock to compensate for fork changes
captmoto
Rancho Cucamonga, CA, USA
7/30/2020 10:44am
You need to explain more about fighting the shock. What kind of movement? Front or rear? Maybe get a good sag setting, go back to stock and start over, one adjuster at a time.
What MXA did with their 125. Have you considered maybe servicing your suspension?
https://motocrossactionmag.com/amp/mxa-race-test-2017-husqvarna-tc125/
Tuna
7/30/2020 11:38am
Maybe you should concentrate on dialling in the shock, not the forks.
You are saying you are fighting the rear, not the front.
TC125
7/30/2020 11:46am
I have had the shock apart and changed oil 3 times so far this season, fork seals/oil a few weeks ago, stock sag from the manual, lower air pressure made a noticeable difference on the movement of the forks but also seemed to help eliminate the sharpness from acceleration chop on the rear suspension. Doesn't make much sense to me - maybe the front is a touch lower and the rear slightly higher when coming out of a corner or something. It makes sense that the front wouldn't be as stiff with the lower air pressure but interested in how it seemed to help the rear
Post a reply to: AER Pressure
