Monroe, NC, USA
Hello all, I have a trouble bike, or ghost messing with me, it is October. I have 2016 KK100 with at least 80 hours on it, 36 hours on the top end. It's used mostly for scramble races, has a PC pipe/silencer, Vforce Reeds, 9oz flywheel weight as mods. During a race he says it just starts to bog, and will not get on the pipe at all. Finish race and check pressure, it's good cylinder pressure at 162psi. Replaced the governor assembly, and put everything back together. Engine won't clear out. It like the choke is on, but it's not. It revs up but will not clean out. Running VP T2 and still nothing, replaced the plug, still same. Crank rod is within spec so I don't think it's that. Would a crank seal cause this to happen, not rev out? Also the power valve assembly has been taken apart, cleaned and put back with a new top end kit, with new gaskets etc.
Any info would be appreciated.
Air filter have too much oil in it?
Post a reply to: 2016 KX100 - Not Hitting Powerband
