Belle Chasse, LA, USA
8/4/2021 5:55pm
Having some issues with a friend of mines bike. Its a 2015 ktm 450 sxf FE. Problem is the bike wont turn over, chirp, or relay click when the start button is pushed. The bike has a brand new battery, wps lipo. Checked the plugs, connections to the battery and fuses already. Cant figure this out. Any suggestions?
The best thing would be to find the same year bike and start swapping parts.
If not, check the start switch. If yes, then check the starter wires and grounds.
Also check the starter relay. They do fail. They work just like an auto starter relay and if it does not get power it will not work. They also just fail from usage, but not real often.
tend to break at the connector from bouncing up and down. Eliminate the connector and hard wire the starter
switch.
You need to remove the gas tank and unbolt the regulator to really see it so it's very easy to miss.
Post a reply to: 2015 ktm 450 FE electrical help?
