Delaware, AR, USA
9/16/2015 6:19am
my step son has a 08 crf250 that the valves need replaced, if we go with the stock valves can we install ourselves or do the vavles have to be cut?
thanks
thanks
I would pull the head, disassemble and check it out. You have a couple options after you inspect head...
- if seats are in good shape, lap SS valves in
- send original head out and have it rebuilt
- buy new stock head and valves
You can't lap OEM valves.
A valve seat touch up is cheap BTW...
Free shipping: VITALMX
If the valve seats don't need to be cut, there is no sense in wasting a cut. Generally you can only get away with two separate valve seat re-machining's before the valve stem protrusion measurement becomes too large making it hard to shim the valves.
If the stock seats are in good shape, I would recommend switching to either the Kibblewhite stainless intake valve conversion kit or the Xceldyne X2 stainless intake valve kit.. both good options and both will far outlast stock or any other titanium valve.
Post a reply to: valve replacement??
