Vital MX fantasy is free to play, but Premium users receive great benefits. Premium benefits include:
- Pick trends
- Create a private league
- And more!
Only $10 for all 2026 SX, MX, and SMX series.
Two questions for you. Where did you get the jig for the engine?
What jetting specs are using? I have an almost identical engine set up and the same carb and I'm looking for a starting point for jetting.
Thanks,
Colin
Thanks! I purchased the jig from "Kevin S" on the now defunct www.bannedcr500riders.com and have sold it since the build, regretfully.
I purchased a Keihin PWK38 Air Striker (quad vent) from carb parts warehouse. Tom Morgan Racing taper-bored it to 39.5mm. I'm about 100' above sea-level in North Carolina, and at this time of year my jetting is:
52 pilot
1.5-2 turns out on air screw
CE-J needle, 3rd clip
175 main
I started with a 55 pilot and 180 main to be safe, but it was pig rich at 80degF. The current setup is perfect at 65degF at 100'.
Nick
EDIT:
I use straight VP C12 with Amsoil dominator at 40:1
Did you have to adjusting the timing at all on your ignition or were you able to just run it as is? I have an 01 CR250 ignition system for mine.
Best regards,
Colin
Not a problem! Running the CR250 ignition on full advance has been the best result for me.
Nick
Post a reply to: COMPLETE!!! CR500 Aluminum Frame Conversion Build
