3D CAD studs, I need your help!
Falcon
Menifee, CA, USA
OK, someone here must know how to do what I'm trying to do. Keep in mind I know virtually nothing about CAD, except how to move it around in my Acrobat viewer.
I have two STEP files that I need to convert to "UG" format so the parent company can manipulate them and do some virtual testing. Apparently, nobody here can support UG format, and it's the only format they can or will use in Japan.
From what I can glean online, this means we're trying to go from Solidworks to Siemens in some way. Help????
early
University Heights, OH, USA
12/20/2017 9:01am
Did 2 minutes of research. Looks like UG is NX now. My Inventor doesnt have an export option for either format. Why cant they convert it from stp themselves? Sorry I am no help at all haha
Falcon
Menifee, CA, USA
12/20/2017 9:07am
Yeah, I was getting that same answer from Google myself. I still don't see how to convert .stp to NX though.
colintrax
Taylorsville, GA, USA
12/20/2017 9:19am
Download a Japanese copy of solid works and convert to ng for them? I don't know. Honestly just seems silly. Just make sure you save a duplicate before trying to convert it, just in case.
Falcon
Menifee, CA, USA
12/20/2017 9:27am
It does seem silly. I can't believe that their program won't open a STEP file. It seems pretty universal from what I can see....
12/20/2017 9:43am Edited Date/Time 12/20/2017 9:43am
Your virtual testing I'm assuming is FEA? If so almost all commercial FEA programs accept STEP files. At least the ones I work with.
Falcon
Menifee, CA, USA
12/20/2017 10:00am
The virtual testing will be for fitment and shape, so....
FEA= Finite ____ anaylsis? Sounds about right.
The problem is that my parent company's program doesn't appear to accept anything other than UG format. Apparently, all the automotive manufacturers use it but nobody else does.
seth505
SD, CA, USA
12/20/2017 10:19am Edited Date/Time 12/20/2017 10:20am
Yes, FEA = finite element analysis. Not sure why it wouldn't take STEP (or IGES) as well. I use Creo Parametric and can save as almost anything but not NX, sorry.
Falcon
Menifee, CA, USA
12/20/2017 10:41am
seth505 wrote:
Yes, FEA = finite element analysis. Not sure why it wouldn't take STEP (or IGES) as well. I use Creo Parametric and can save as almost...
And now you feel my pain. Every program in the world can import/export from/to everything except UG, apparently.
seth505
SD, CA, USA
12/20/2017 10:58am
Ya, it's crazy. I can import NX stuff fine but cannot export as that file type, just every other type known to man!
1/4/2018 6:36am
Falcon wrote:
The virtual testing will be for fitment and shape, so.... FEA= Finite ____ anaylsis? Sounds about right. The problem is that my parent company's program doesn't...
Falcon, sorry for the super slow reply. Yes, FEA = Finite Element Analysis. Did you ever get your problem resolved?
Falcon
Menifee, CA, USA
1/4/2018 9:55am
Yes, I got the problem fixed. My vendor was able to export the file to .x_t format and it worked in the UG program.
Post a reply to: 3D CAD studs, I need your help!
