Beginners maintainance schedule for a 2 stroke
Hi all,
First post here so you will have to bear with me!
I'm fairly new to motocross. Despite having watched my cousin race most weekends, my parents didn't have enough money to buy me a bike growing up. This year (aged 29) I decided to take the plunge and brought myself a Ktm 250sx 2004. I've had 3 practice weekends, and 3 race meetings so far, and despite being terrible, I'm having tons of fun! I'm finding myself constantly counting down the days to the weekend, like I'm sure a lot of you do.
Anyway as I'm not really mechanically savvy, I'm struggling to find out the key maintainance I should be doing on the bike. Can someone please give me a run down on the things I should be doing after every ride/ every month/ every year. I dont want to be the guy who buys a nice bike, then trashes it because he hasn't looked after it.
Any help appreciated.
Thanks
colintrax
Taylorsville, GA US
2562nd
6/7/2016 2:52pm
Do you know when the last time was the bike got a new top end (piston and rings)?
If you don't know, it doesn't hurt to replace it now. Inspect the cylinder to be sure there's no scratches, or gouges. Just the cross hatching. Good idea to repack the silencer now too.
Change the transmission oil every couple rides (I go 4 to 6) clean the air filter every ride, grease all the bearings a couple times a year, replace top end every 60ish hours on the bike. Check the crankshaft when doing a top end. Replace spark plug as needed.
6/8/2016 9:32am
colintrax wrote:
Do you know when the last time was the bike got a new top end (piston and rings)? If you don't know, it doesn't hurt to...
Thanks for the reply!
No idea on when the last rebuild was done, it might be something I get done in a few weeks.
I noticed a small weep of oil on my forks, so I have brought a little seal doctor tool and got all the muck from under my oil seal, seems to have done the trick. Il make sure I change the transmission oil the weekend before I ride as I don't know how long that stuffs been in there.
Thanks for your help, seems like fairly easy maintainece on a weekly basis, with the big stuff needing doing 1-2 times a season.
JWACK
NM US
6/8/2016 12:26pm
buy the service manual for the bike and read it, purchase a decent tool set if you haven't already... lube your chain every ride. Check your tire pressures every ride.. keep an eye on your air filter. If it's got dirt on it clean it, if not don't. Replacing the Top end is a good idea as trax said. Purchase a cheep hour meter. Check your spokes and sprocket bolts almost every ride.
colintrax
Taylorsville, GA US
2562nd
6/8/2016 10:56pm
Hi all, First post here so you will have to bear with me! I'm fairly new to motocross. Despite having watched my cousin race most weekends...
Hi all,
Thanks
Good point on the spokes, totally forgot to mention that.
However OP I strongly suggest you give a mechanic $20 to spend a few minutes teaching you the sound to listen for. There is such a thing as over tightening, which can lead to broken spokes/wheels just the same as not tightening the spokes. I'd ask around at the track for suggestions on which mechanic to talk to, and possibly use for work. There's some real smart guys out there... and there's some dummies. Make sure you're not taking advice from the dummies.
Generally when I see oil seaping out, I say it's time for new bushings,seals and oil. The oil in the forks and shock need to be replaced occasionally, the shock needs to be recharged as well.
6/12/2016 6:32am
Replace the clutch plates with every top end change. Check the engine mount bolts every other ride, along with a general check of all fasteners. Keep the coolant topped up.
Before you wash the bike, cover the exhaust opening. When the bike is clean, that is a good time to look the frame over for any cracks.
bronwynrayne
Harrisburg, OR US
6/14/2016 9:09am
Everything that the guys have mentioned above is important, especially preventative maintenance. It's a good idea to have a check list on a whiteboard in your shop or garage that you can write the dates on for oil changes and hours for your top end, etc.
For me, oil changes are very regular, around every 4-6 rides as mentioned above, and an air filter clean after every day of riding. Sometimes it's a good idea to have a spare air filter around so that you don't have to rush it if you're beat and want to ride the next day.
Always check your coolant and your sprocket screws before you ride.
This book is really awesome and available online... I would suggest you get it and read it! It's an easy read with lots of tips for people like you and I who weren't brought up riding bikes.
https://www.amazon.com/Motocross-Off-Road-Motorcycle-Motorbooks-Worksho…
WVUpetro2013
Hurricane, WV US
6/15/2016 4:39am
May sound trivial, but buy an hour meter. I bought one off of amazon for around 15 dollars and is a good way of tracking when work needs done. Also only took 5 minutes to install.
K-dubbb
6/15/2016 5:16am
Hi all,
Thanks
colintrax wrote:
Good point on the spokes, totally forgot to mention that. However OP I strongly suggest you give a mechanic $20 to spend a few minutes teaching...
Good point.
I've built and maintained numerous wheels and there are 2 keys (to keep it safe) : Even disbursment and 1/8 turns.
Start at the rim lock and go all the way around, each spoke 1/8, bike on stand is easiest.
It may feel weird if some are loose and others may be tighter, but keep going - those are likely spots the wheel is untrue but straightening isn't your objective in the tension/maintenance stage.
Others may suggest different but this is what I've always stuck to and have had really good luck with my wheels, given the amount of casing I do Smile
Btw, I am a late starter too, lived vicariously through my mountain bike before. Have fun man, you will soon (if you haven't already) fall in love with riding.
6/15/2016 10:49am
Thanks for all the replys guys!!
I took the bike out the over the weekend in pretty torrid conditions, and have spent 2 days getting it properly clean!
I have been ensuring the air filter is always clean and lubed, chain is lubed. I have changed the transmission oil today, and will be checking the spokes and sprockets tomorrow. Also need to check tightness on all the bolts. I should have checked all this before i rode it, but i just couldnt contain my excitement. This led to me losing 2 bolts out of the side panel, and 1 radiator popping off the mounts as they werent secured.
Thanks for all the advice. As someone who has never even so much as changed a plug, im enjoying taking things apart and understanding how they all work
PTECH
Phoenix, AZ US
7/9/2016 11:51am Edited Date/Time 7/9/2016 3:51pm
May sound trivial, but buy an hour meter. I bought one off of amazon for around 15 dollars and is a good way of tracking when...
This is a good idea. That and keep a log book of the maintenance you're doing. Its easy to forget when your last oil change was and accidentally go a long time without changing it.
Post a reply to: Beginners maintainance schedule for a 2 stroke
