2002 cr125 problem
andrewb399
New Baltimore, MI, USA
My friend has a 2002 cr 125 that he bought for 900. I took it for a ride to see what was wrong with it, it started up no problem but it was idiling high and everytime i hit the throttle there was no power at all in the mid to high range rpms, it was almost impossible to wheelie or even do a burnout. when you hit the throttle when it is idiling it will bog. i feel like it is something wrong with the airscrew but i dont know. maybe the carb.
gsxr6
Anderson, CA, USA
4/7/2017 3:07pm
Plugged main jet? Does it run better with the choke on?
andrewb399
4/7/2017 3:09pm
It stalls right away when the engine is warm and the choke is turned on
Rockinar
Katy, TX, USA
4/7/2017 7:13pm
It came pre-clapped out before you could kill it doing burnouts. Nothing wrong with it.
Cygnus
Hanover, CO, USA
4/7/2017 7:16pm
Power valve is sticky.
gsxr6
Anderson, CA, USA
4/7/2017 7:30pm Edited Date/Time 4/7/2017 7:30pm
Keep it running choke off, and turn off the gas. Does it run ok right before stalling? That'd be a sign it's too rich
dblD1968
Bozeman, MT, USA
4/7/2017 8:42pm
High idle and low power usually means lean. Pull the carb and see what Jets it has and make sure they are clear
toomey706
Dripping Springs, TX, USA
4/7/2017 8:50pm
Burnouts are f****** cool as s***. Lmfao!
andrewb399
4/7/2017 10:41pm
Main jet isn't plugged, and right when you turn the choke on it stalls
xplane
Houston, TX, USA
4/8/2017 12:12am
You bought a old 125 for $900 how have you not taken the cylinder off and changed the top end at the very least. You can do damage to the bike if you run it with a worn enough ring since the piston will slap around.
Post a reply to: 2002 cr125 problem
