RM250 K8 Triple Clamp Advice
Neo78
Which aftermarket clamps fit the 2 smoker please?
Joyner41
Rohnert Park, CA, USA
4/12/2019 5:11am
Ride Engineering makes a set that worked flawlessly on my 125. Plus the HPSD Mount is an added bonus.
b8res
Lodi, CA, USA
4/12/2019 11:54am
Applied has a nice set as well.
Neo78
4/13/2019 2:06am
Do you know of they hold 48mm forks?
Turbojez
PL
4/25/2019 2:05am
What kind of 48mm forks?
I know for sure that in order to use other forks you will need non-oem triple clamps or bore out your stockers.
For example I went with Yamaha KYB forks, and had to use Kawasaki triple clamps with suzuki RM stem for them to fit properly.
HackMan162
Austin, TX, USA
4/25/2019 5:37am
Turbojez wrote:
What kind of 48mm forks? I know for sure that in order to use other forks you will need non-oem triple clamps or bore out your...
This ^
If you call Applied, and tell them what you are trying to do, they will likely be able to accommodate you.
Neo78
5/16/2019 5:01am
thanks for the advice
Post a reply to: RM250 K8 Triple Clamp Advice
