Need help YZ Swingarm conversion
mxteach
New Windsor, MD, USA
Edited Date/Time 2/16/2021 8:15am
I have done the conversion to the swingarm but I have a question for anyone that can help or has done this......
Where can I get a shorter dogbone link?
I am using the Stock YZ250 dog bone with a YZ450 Swingarm.
It makes the rear squat a little too much......
TIA for any help (and yes I have read the other posts on this conversion but i have it all hooked up and working just trying to figure out which dog bone will give the correct ride height)
mxteach
2/15/2021 5:19pm
2/15/2021 6:04pm Edited Date/Time 2/15/2021 6:06pm
I was about to comment on that in your build thread, but then I saw this. What you need is a 143.5mm arm to get it back in stock YZ spec. The only one I know for sure that is 143.5mm is the PC link YPA10450.
Killer build, BTW.
mxteach
2/16/2021 6:12am
I was about to comment on that in your build thread, but then I saw this. What you need is a 143.5mm arm to get it...
Killer build, BTW.
Thanks! That was the direction I needed. Now Quick question do you think stock 450 linkage would work its 142mm?
2/16/2021 8:15am
No, that will jack the back end up too much. Just the opposite of what the YZ pull arm does. I tried running more sag with the 142mm arm, but it seemed to blow thought the stroke, or like the progression was gone.
When I did my first one I tried a bunch of arms and a couple of adjustable arms. If you want to squat the rear a little, like what a longer arm with the stock swingarm and rocker does, then a 144mm arm is about right for that. Personally, I didn't care for that either.
It's pretty amazing how much a slight change in that length affects the bike.
Post a reply to: Need help YZ Swingarm conversion
