- Pick trends
- Create a private league
- And more!
The problem may be the axle from 2015 and on.
I have a set of forks but the right inner tube is dented.
Suspension Front 49mm inverted Showa SFF-TAC Air fork with 16-position rebound and 16-position compression damping adjustability. 12.2"
2016 Kawasaki:
Suspension Front 48mm inverted Showa SFF telescopic fork with 40-way spring preload adjustability and 22-position compression and 20-position rebound damping adjustability 12.4"
2011 Kawasaki:
Suspension Front 47mm inverted Showa SFF telescopic fork with spring preload adjustability and 22 position compression and 20 position rebound damping adjustability/ 12.4 in
I have a taken apart kx250f fork for a 2011.
Post a reply to: 2011 Kx250f Front forks
