Yellow Pine, ID, USA
Anybody done it?
The crappy steel ones bend so easy, I've bought 3 sets now. $56 each on Rocky Mountain....
It's not exactly straightforward to put on aftermarket ones because the bars and clamp are one piece and the choke and key are also part of it.
I took the key off awhile back but I'd still need a solution for the choke.
Anybody smarter than me that can help?
I might have some helpful information, I’m 99% sure you can use a crf50 top triple clamp mount and then mounts any 7/8 bars on to that. You will probably need longer cables and all that depending on bend and all that.
https://www.planetminis.com/threads/ttr50-crf50-same-forks.73497/
Here is a link for some information
Or Depending on how you want to do, you can fit the ttr110 complete front end on.
I wonder if that still works since the newer TTR50s have right side up forks and not the upside down like the CRF.
I kinda wish I woulda just bought him the Honda but that magic button is pretty awesome for trail riding....
Yea. I’m not entirely sure, ours is a 2008 I believe, sucks there not a ton of parts anymore for these things
I have a buddy with a CRF, we may just have to grab a case of beer and do some tinkering.
Free shipping: VITALMX
Not cheap, but: https://www.fast50s.com/i-18479566-fast50s-yamaha-ttr50-fast-clamp-2006…;
Good find, somehow I hadn't found that.
However, I think it fits the one with the other forks. I'm gonna reach out and see.
I should put the year of mine in my first post.
*Edit, dug a little deeper and they make one for the current generation too, sweet! Thanks man!
https://www.fast50s.com/i-23901772-fast50s-yamaha-ttr50-fast-clamp-2018…
U can use bar clamps off of some other bikes also I’ve used atc70 bar clamps in the past. The bars should bolt through the top plate. If you take it off there will be nuts to pull off the bars.
Post a reply to: TTR50 Aftermarket Bars?
