Working on installing my racetech gold valves, per my DVS sheet my Low Speed stack needs (3) .25x19 shims, however the kit only came with a total of (4) .25x19 shims. I have enough.15x19 and .10x19 shims to create the same overall thickness. My understanding is that (5) shims measuring .75 won't perform the same as (3). My overall question is will I be fine to do this and not notice it or should I just go ahead and order a couple shims?
Suspension Valving question
Jacksonville, NC
5/22/2026 5:41pm
Ask Race Tech! Their support is super helpful. I had a similar issue and if I remember correctly they told me I could substitute a slightly thicker shim and also offered to send more shims. The suspension was a huge improvement over stock!
Thank you I plan on hitting them up!
Thick divided thin, cubed.
.25/.15= 1.67.
1.67x1.67x1.67=4.66
4.66x3= 13.98
13.98 .15x19 shims equal 3 .25x19 shims.
Post a reply to: Suspension Valving question
