Hello, my son races a 26 YZ250f. This week we had an issue where the bike would crank but not start. This happened at Saturday practice so I had all day Saturday and Sunday to check and try everything I could think of. What I ended realizing was when the bike wouldn't start, it also wouldn't communicate with the app. It wouldn't put out a wifi signal. I noticed after cranking it a ton if the app would pop up then the bike would run. I ended up basically keeping the ECU "awake" by hitting the start button once every minute or so. As long as I didn't let the bike "sleep" it would start every time. Now Monday morning and the bike started right up but when I press the map switch on the bars it doesn't light indication that it switched maps. Any ideas?
Starting issues YZ250f
RUSH, NY, USA
The stay ignition coil could be going out there us also a diode in the the harness
Try holding down the kill switch for 10 seconds then start... works for my bike.
I would replace kill switch assembly. They get corroded over time from washing.
Agreed. I have since found that the bike will not run unless it's unplugged and dies once plugged back in. The fact that the part is on backorder is telling also. I was going to verify a definitive fix and then post it but I think you're right. Thanks!
Post a reply to: Starting issues YZ250f
