Routine engine maintenance on 2022 yz450f
mtbkris2
San Diego, CA, USA
Edited Date/Time 3/26/2024 8:08pm
I’m at about 50 hours now, just wondering what you guys are doing at this point in terms of engine maintenance. I’ve heard a lot of differing opinions on when to do my top end, so not sure if now is the time or I should wait another 25-50 hrs. Should I check my valves? Should I replace my timing chain?
I’d consider myself mid to upper novice after spending several years off the bike and I do wring the throttle more than most vets. Oil and filter are done every 1-2 rides. Air filter every ride.
3/27/2024 5:15am
I’d start thinking about it around 70 hours or so. If you’re not holding it on the chip all the time and keep your filters clean I don’t see you having a problem until then. I’d wait until then to check the valves unless it’s having trouble starting.
3/27/2024 10:50am
I would do a leak down test and check the valve clearance.
27thmx
Naples, FL, USA
4/21/2024 4:20pm
I would say a piston at 75 hours should be safe for a 450. It just depends on how hard your ride and maintenance.
Post a reply to: Routine engine maintenance on 2022 yz450f
