Pro Circuit works vs platinum vs platinum 2
JakeM250R
what’s the difference in power between all the pipes I can’t find a clear cut answer other than the thickness of each one. The races I do are 50/50 woods and motocross so I’ll be in single track then 20 seconds later be wide open in southwick. Any advice on what pipe would give the best all around power gain if there’s a difference between them and which would have decent durability.
I ride a yz250x so the bike already has a decent amount of low end.
thanks in advance
MxAddic
12/22/2023 11:38am
Not sure about thickness but the nickle pipes would be better for the woods based on durability.
DynoDan22
Victorville, CA, USA
12/22/2023 12:13pm
The Platinum 2 has a thicker wall section than the Works and the Platinum. The Platinum is just a nickel plated Works pipe where the Platinum 2 is more geared towards enduro because it’s thicker and less prone to denting. As far as I know, there is no effective difference in pipe performance.
Post a reply to: Pro Circuit works vs platinum vs platinum 2
