OLD 1962 Honda Carb Help
DF313
Ogden, UT, USA
https://www.partzilla.com/catalog/honda/motorcycle/models-with-no-year/ca105t-a/carburetor
See above link to the carb that is most similar to the one I am working with.  Although the bike is a 1962(?) C105, 55cc Honda Cub, I think...
Anyways, here is my carb issue, the bike starts easy, idles great, both idle and air screws function and change the characteristics of the carb as they should.  But if I give it even a little gas, it will stumble and die UNLESS I set the idle pretty high, then it will break through and run very strong.
So if it were on a scale, and
1 was idle, runs perfectly,
2-3 slight stumble and dies if idle is regular but breaks through if idle is set high
4-10 runs super strong, very responsive, revs out great ect.
I have cleaned the carb at least 10 times at this point.  Any old time gurus out there that might give some insight?  I have moved the needle clip from lean to rich and back, with varying results, but none that fix the problem.
Thanks!
peterc3004
Kilsyth, VIC, AU
6/12/2024 4:57pm
Have you set the timing and points gap?.
I have found getting the points ignition spot on helps to reduce the bog on cracking the throttle.
DF313
Ogden, UT, USA
6/12/2024 8:09pm
Good idea, I'll check it now!
DF313
Ogden, UT, USA
6/12/2024 8:54pm
That was it!  I was just slightly early in the timing, runs great now!
Post a reply to: OLD 1962 Honda Carb Help
