Lectron on a 06 cr125
Hello, I have a 06 cr125 I’ve built and I have a lectron carb but I’m having trouble fitting it. Do I need a different cable to use with the stock throttle housing or do I need a cable and the domino housing? I don’t know what cable to buy. I have the stock housing and a domino housing.
Also, what do I do with the TPS sensor from the other carb? Can I just unplug it or do I need to disconnect it from the old carb and plug it back in and water proof the end? Any info or help would be great
thanks
Honda Man 66
Atlanta, GA, USA
10/16/2023 6:54am Edited Date/Time 10/16/2023 6:55am
I had cable / throttle housing fitment issues when installing a Lectron on my CR250. I was able to file the barrel down so that it was not so wide and then it fit the stock throttle housing. The Domino throttle housing supplied with the carb looked like junk to me. I unplugged the TPS up under the tank and taped it up.
TDC
HTown, TX, USA
10/16/2023 9:28am
If new to Lectron, call them up. Also, be sure to not have an over lean setting. Had a buddy blow up his 125 once he installed one of these carbs pre-set to his 125. He did lack experience for detecting the condition. He educated now, it was a very expensive lesson.
Post a reply to: Lectron on a 06 cr125
