Husqvarna tc85 help (spring strength)
maesr
Cork, Co. Cork, IE
Hi all
I'm new to mx bikes and I recently bought a 2022 Husqvarna tc85. It came with a WP 40-215 G/R rear spring. The problem is that this is far too soft for me. I weight 72kg (160lbs). I am looking at springs but they all have a different Nm rating. Which Nm rating would I require to help stiffen up the rear suspension. Please note that I already adjust the suspension to it's hardest setting.
Thanks for your help
Factor E
So Cal, CA, USA
9/22/2024 5:47pm
CHECK RACE TECHS WEB SITE
FGR01
9/26/2024 4:02pm
Here's what the manual says about the spring rates.  Stock 40N/mm spring is for 99-121 pounds.
image 508
Husqvarna Sells 50 and 55 N/mm springs as options also.  Looks like you need to get the 55 spring.
image 511.png?VersionId=m1NUdEYT QayLYKLgyqWbOf
Post a reply to: Husqvarna tc85 help (spring strength)
