Cr125 pro circuit
Will a 05-07 pro circuit pipe fit 02-04 need to know if anyone has done this
3/12/2023 10:18pm
I installed a 04 pc pipe on a 06 cr125.  It had massive snap off idle Very quick but only pulled to 9k & stopped quick & would not rev out. The pipe fit but there’s no way to short shift as quick as the pipe signed off on a track.  03, 04 share the same pipe. But there radically different engines.
3/12/2023 10:23pm
I installed a 04 pc pipe on a 06 cr125.  It had massive snap off idle Very quick but only pulled to 9k & stopped quick...
Ok then so I know the motors are different....but your saying all the pipes are the same 02-07 so what it is I need to find out is will the 05-07 pipe fit and bolt up to a 02-04 cheers mate hope u can help
Tumic
Sundsvall, SE
3/14/2023 10:08am
Badman250f wrote:
Ok then so I know the motors are different....but your saying all the pipes are the same 02-07 so what it is I need to find...
They bolt up.
3/14/2023 10:11am
Tumic wrote:
They bolt up.
How do you know
Post a reply to: Cr125 pro circuit
