92 cr125 help
Trying to do a light restoration on a 1992 cr125 I’ve had for a bit.
1. What other year footpegs fit on this bike? Since this bike comes stock with pegs pretty much an inch wide lol. Iv heard yz footpegs fit on the mid 90s CRs but was sure if they fit the earlier ones too.
2. Will a mid 90s cr125 19 inch rear wheel fit right up? It has an 18 inch wheel which I don’t really care about but I have a really nice set of 95 cr125 wheels in a lot better shape, and 19 inch tires are just easier to find. I also read about PC putting 19 inch rears on the peak bikes so that’s cool too.
3. Will a 1990 pipe fit the 92? I also have a nice 1990 works PC pipe that needs some tlc but would be cool to run on this bike.
Thanks I’m advanced for the help! I might post a quick bike build on it, if it turns out semi decent.
2/12/2025 2:46am
i did a 93 a couple of years ago buddy and keep notes (im old) lol, on your question number 2, the rear wheels are the same fitment from 1987-01 CR500, 1987-99 CR250, and 1987-99 CR125, but rim width is 1.85 wide on 125.1989-01 rear wheels had 32 spokes, 87-88 had 36.
Front wheels will work 1984-1994 for info, there a great fun bike when done
sandman768
Saratoga Springs, NY, USA
2/12/2025 5:29am
1. Late model YZ pegs,springs & pins fit, not sure about the last 3-4 years but anything up to those years Yz will fit. if you lucky you can score some stock Ti pegs for very  cheap, although likely starting to dry up.
2. The most definitive way to check wheel fit is to try & mount your 19inch wheel, they did increase bearing size and disc size at some point. I run the stock 18in rears on my 89 & 93 CR”s, yiu can still get good tires for 18 rears.
3. Pipe fit is 92-97 the older pipes are close but slightly different angle of front mount and rear mount changed locations.
Photo of Yz pegs on my 93 CR125IMG 4278 3.jpeg?VersionId=n2g0 8G8TR fFE.ydFhZAYW8UZ151
Banana_oil
Gothenburg, SE
2/12/2025 9:42am
Modern yz and ktm pegs fits 95-97 frame. Previous years had narrower fixations.
The hubs from 89 to at least 96 should fit 92.
The pipes fits 90-97.
Inferno
Laguna, IC
2/13/2025 2:38am
I've used for years the DRC pegs on my old dirtbikes. Great japanese product, with oem/standard look.
https://www.ebay.es/itm/266838529691
About rims and pipes, it's all said.😉
3/3/2025 4:53am
Well unfortunately for whoever told me the 1990 pipe would fit on the 92, it does notSad but I got a nice 1990 pc pipe for sale if anyone is interestedIMG 7004 1IMG 7005 2.jpeg?VersionId=QdB6NN8vbeZ0709PxIMG 7007 5
sandman768
3/3/2025 5:07am Edited Date/Time 3/3/2025 5:08am
I tried to tell you about pipe fitment, I have a collection of 90”s Cr125 pipes…its 92-97…but nice job on the pipe restore👍 …blue the welds and clear coat with heat paint… it will sell on a CR Facebook page….
Post a reply to: 92 cr125 help
