spring glen, NY, USA
Hoping someone can provide me with a possible solution. I have a 2023 YZ450F and the blue light on my kill switch side/ button cluster is staying illuminated. When the bike is off or on etc… I tried a new switch as well as cleaned out my ESU due to it throwing a fault code. I no longer have a fault code, but something is causing the light to illuminate.
Has anyone else had this issue and how did you go out fixing it?
thanks
Stephen
info on this thread https://www.vitalmx.com/forums/Moto-Related,20/New-2023-YZ450F,1401205?…
i have same issue did you find out what it was ?
Mine too, any answers?
That's not the map switch button is it? I can't remember how the control cluster is layed out. If that light is on....it's in map 1....off....map 2. Just double check that it's not that.....something super simple.
It IS the map button, but it doesn't do anything, except STAY ON, no matter what you do. I even unplugged it at the map computer, and it stays on until the bike goes into sleep mode.
Is there anything weird with the Yamaha app when you connect it to your bike?
Not that I've noticed
delete the app.....reload it and set the bike up with the wifi as if it was new. Make sure you have the latest updates on that app. I would absolutely start there before replacing stuff
Post a reply to: 2023 YZ450F blue light issue
