2 stroke pipe dent removal
Are there any companies still doing this? I know fusion one stopped a while ago, and I remember reading the whole pacific crest pipe repair debacle. I’ve looked into the DIY plug kits to use air/heat but not sure I want to tackle it myself. It’s a pro circuit pipe off my 125 that was cut and modified for the motor work done so I can’t just get another one off the shelf.
Falcon
Menifee, CA, USA
12/5/2022 1:25pm Edited Date/Time 12/5/2022 1:45pm
In the worst case scenario, you can cut it in half right along the dent and then have a regular, old welding shop weld it back together. It'll look like ass, but it works. (Make sure to make specific marks where the two pieces should join back up or your fit will be all wrong.)
EDIT: (Straighten the dents out after you cut the pipe in half. Hopefully, that part was clear.)
12/5/2022 1:39pm
Getting dents out is easy with a plug kit. Restoring a dented pipe to look new is a different story. I got my kit from Europe I believe, it works well
b8res
Lodi, CA, USA
12/5/2022 8:04pm
Rickyisms wrote:
Are there any companies still doing this? I know fusion one stopped a while ago, and I remember reading the whole pacific crest pipe repair debacle...
jmc2
Gilbert, AZ, USA
12/7/2022 8:04am
Another vote for Front Range Pipe Repair. I sent him an "exhausted" pipe for a CR250 with dents and rust. He was able to repair and strip remaining paint and give the pipe a works look.
Wycked31
West Palm Beach, FL, USA
12/8/2022 10:51am
Check out Tyler Winstead on Facebook. He does a great job and can even strip a plated pipe
Post a reply to: 2 stroke pipe dent removal
