Cleaning / Restoring swing arms and frames
Sparkalounger
Minneapolis, MN, USA
Hi everyone,
I am wondering what the best process is to restore swing arms and aluminum frames?
I have seen some amazing work that looks as good or better than new.  Specifically looking for swing arm help.
Also, is there a sealer to apply at the end of the process?
Your help would be appreciated.
- Chad
sandman768
Saratoga Springs, NY, USA
3/28/2023 6:33am
Depends what you are working on… some arms were painted, some anodized…some have a grain that needs to be replicated…show us what you are working on…
Sparkalounger
3/28/2023 7:29am
Thank you Sandman.
I don't have any pictures right now but can get some.
This is what i would call a standard finish on modern dirt bikes.  Looks like unfinished aluminum with grain running the length of the swing arm.  But i am under the impression that there is indeed some type of clear coat over the aluminum?
This happens to be on a 2000 Montesa trials bike.
Sparkalounger
3/28/2023 7:35am Edited Date/Time 3/28/2023 7:36am
image-20230328093540-1
Sparkalounger
3/28/2023 7:36am
Guess I did have a couple on my phone image-20230328093653-1here...
Mr Happy
3/28/2023 7:48am
The grain is a brushed finish. I usually use a medium Scotchbrite wheel to clean it up and then a P120 pad by hand to get an even finish all running in the same direction. 240 is probably closer to most factory finishes although 120 helps to disguise knocks and gouges on older bikes. I leave it bare and have a bike done over 10 years ago that still looks good.
sandman768
3/28/2023 8:32am
As Mr happy states, always go with the grain when sanding the arm. Clean it best as you can before any sanding work. Any deep digs or gouges can be carefully cleaned up with a small die grinder tip or dremel tip. Remember to not go any more aggressive than you need to with abrasives. I have left anodized arms bare after stripping also with good results. I have also had good results with a vapour blasting aluminum parts after initially cleaning & removing any digs or gouges.
3/28/2023 1:55pm
Hi everyone, I am wondering what the best process is to restore swing arms and aluminum frames? I have seen some amazing work that looks as...
Hi everyone,
- Chad
Use that Wire Brush for all Aluminum parts on my KTM‘s with a good Result
AF130718-1602-42D0-860C-67F7A78FDE9E.jpeg?VersionId=PEbBX2p8nT
6327E0DA-4CA7-4F36-BF12-C342E139A20E.jpeg?VersionId=I9A26Etv01R.NnkfT7c.3
ED58410B-CF8C-4C7B-81FE-F6C66AA96CD5
760864E2-62F1-4C78-BD41-DFDF29A65571.png?VersionId=U3rwK0qw0ByVleVIbD5.ubx5V6
0BA90857-A475-436B-AECE-4F36E4A7B3D9
BC886D5A-C436-47CA-BECD-643AD8C34A48
Post a reply to: Cleaning / Restoring swing arms and frames
