can anyone give me a little help on picking the right sprocket? it's a 06 rm125 and I was thinking of maybe doing a 52t but thought that maybe it'd be too much, stock is 12-51. most tracks that I ride at are more faster with some tight turns. I can get a great deal on either the 47t or 52t but if it's not going to be good for the local tracks i can pass.
47 would be too much.
Are you sure the 12 is stock? I thought it was 13.
One track in particular I ride is pretty sandy and has way more speed to it. I use the 50T. I'm able to use the wheel speed to get on the pipe and really use all the power with the longer gears.
Another is a tighter, harder packed track and has one particular double right out of a corner that I cannot hit using the 50T. 2nd gear is not enough and the 125 just wont pull my 190lb ass in 3rd. 51T is the key at that track. I can use 2nd instead of 1st in the slower corners and 3rd gear will pull me over all the jumps.
47T would be WAY to tall for any 125 IMO.
If you elect to go with the 13/52 set up you will be geared for a higher top speed than the 12/50, which I understood was not the direction you wanted to go.
Also understand that the 2 vastly different tracks you are riding may in fact require 2 different gearing set ups to have the best performance at each.
12/51= 4.16:1
13/52=4.00:1
The higher the number the "lower" the bike is geared. The lower the number the "higher" the bike is geared.
"lower yields quicker rpms, but slower top speed.
"higher" yields slower acceleration, but a higher top speed.
Post a reply to: sprocket sizes
