kx 250f issue - bogging
jasonm649
Peoria, IL US
I have a 2016 kx250f. I got it used a few months ago and I am having some issues. I have been riding on motocross tracks, I usually go into a corner in 2nd gear. when coming out I'm holding throttle wide open, alot of times then I shift into 3rd in bogs down and has no power. Other times I will pull the clutch to avoid crashing or a real low speed inside line on a corner and bike dies. It also acts like it out of fuel. I will have to kick it many time to get it restarted. Do you all think this I fuel pump related. I have taken the injectors out and cleaned them, new spark plug, new oil and filter, new air filter. Anyone having this problem? Thanks
kb228
Mansfield, OH US
7/12/2021 2:48pm
Sounds like a fuel delivery issue. Make sure the fuel pump filter is clean. try a new injector. Make sure tps voltage is correct. Make sure idle speed is correct
Post a reply to: kx 250f issue - bogging
