TTR125 Carb Problems
m1ke20012
Union Bridge, MD, USA
Hi, I have a 2002 TTR125 and I just put the OEM carb back on it off another bike but the problem is, it keeps leaking fuel as if the float or something were stuck. I have cleaned the needle and cleaned and specifically made sure the float wouldn't stick but is there any ideas? Not sure if it affects it, but when I would get the bike started with starting fluid and give the slightest bit of throttle it would die. Thanks.
1/20/2019 2:18pm
The stock carbs are known to be picky with set up. I put a new needle in my 05 to stop the leak and has worked perfectly since.
1/21/2019 2:46pm
New float needle and you'll be done.
Paw Paw 271
Benton, LA, USA
1/21/2019 6:12pm
Your pilot jet may also be clogged. These bikes were jetted very lean right out of the box and they also had a very restricted air flow.
Hondas4Life3
Spring Hill, KS, USA
1/21/2019 7:58pm Edited Date/Time 1/21/2019 7:58pm
These carburetors are notorious for problems. Look up KX65 carb swap. I have done the carb swap and airbox mods and it really wakes the bike up and it runs much better. I had troubles with my stock carb as well. If your on a budget though try adjusting the float height. The little passageway In the bowl of the carb gets clogged easily and is hard to clean.
Post a reply to: TTR125 Carb Problems
