Sag Issue 2016 FC450
Ubtg
san antonio, TX, USA
It's already common knowledge that that year bike was oversprung. I am a 155 pound rider and according to the updated charts and my suspension folks (KREFT) I should be running a 42n rear spring to hit 4-1/4 or 105-107mm sag. Still couldn't hit race sag and had to go with a 39n spring to do it.. and I barely hit it with that; I'm talking very little to 0 preload. They have no record of anyone else with that bike having this problem and probably think I'm crazy. Has anyone else experienced this problem
CarlinoJoeVideo
Portland/Los Angeles, CA, USA
3/20/2019 10:47pm
Is the shock calving stock from the factory?
Is the linkage all greesed and torqued correctly?
aees
3/21/2019 1:44am
I know that 165 pound and a 45 gives you no preload and ~100mm sag on a 350 so you should be close to what you are saying with 39. I assume you are in full gear when you measure sag, and measure according to the book?
3/21/2019 6:43am
Have you thought about using a different company for a spring? I couldn't get it right one time with a spring I forgot the brand and then I put a race tech on it and it was a little softer and I was able to put some preload in it.
Paw Paw 271
Benton, LA, USA
3/21/2019 9:21am
What is your static sag?
Post a reply to: Sag Issue 2016 FC450
