I’ve recently bought a SXF 350 2011, it wasn’t running amazing and had a light on. Had the TPS adjusted then the light went out but was still smoking on idle and didn’t sound amazing. Had a motor rebuild by a guy who’s really switched on. Put the motor in, everything was fine. Ran it in all as you should. It was occasionally cut out on idle if i didn’t give it a few revs but nothing to write home about. I’ve washed the bike, changed the oil, oil filter and cleaned the air filter and the bike will eventually start from cold and as soon as it warms up and i take it off choke it cuts out. It then won’t start, if i let it rest for 30 mins still nothing. I’ve had the injector off and back flushed it (there was what looked like fibreglass in there). Put fuel in. Played with the TPS as it was backfiring so i thought maybe it was running too rich. Cleaned the sensor in the air box. I can hear the fuel pump working. Where else do i go from here? Anyone had any similar problems and if so what was the issue?
Is there a fuel filter in the tank?
Try different ecu?
it cuts out on idle and when the clutch is pulled in without throttle. It runs fine when the choke is on and it rides fine on the track but getting it to the track is a b*tch.
It’s had a full motor rebuild, new injector, new fuel pump and filter and new capacitor.
To me it seems like too low idle and it even sounds like that, i’ve adjusted the TPS to 6, 6.3, 6.8 and 7 and it doesn’t seem to make any difference. Also when I adjust the idle screw it makes no audial difference which I would expect it to pick the revs up.
Tps sensor could be bad also
Did you ever resolve your problem? Having similar issues
Post a reply to: SXF 350 2011 help needed
