Hi, I've got a leaky master cylinder that I can't seem to fix. I've had 2 new sets of All Balls seals to try and stop the leak. Both seals on the piston are seated with the wide end of the seal facing the spring and I believe this is correct. I've had new seals in my caliper and the brake hose is brand new also. I've cleaned the master cylinder out fully with brake cleaner and compressed air.
The leak I believe is coming from the M/C as fluid is running down my brake clevis. It will bleed up but then as soon as I ride it's pissing fluid out again until I have no brake within a lap or two.
Maybe the master cylinder needs replacing? Maybe I need a new piston?
Any help would be greatly appreciated. Thank you.
Post a reply to: RM 250 rear master has me stumped.
