Pw50 qt50 setup
Mxracer394
Hattiesburg, MS, USA
Does anyone have a source for the parts? I can’t find the ring gear on eBay.
project racer
4/22/2020 12:43am
I believe you need to use the QT pinion gear as well. The tooth count is different on both ,if I remember. Found an old QT and robbed the diff a while back. Basically just swapped the axles. Need a press. I let that whole assembly go cheap. Seems like gold now.
Mxracer394
4/22/2020 1:50am
There are several pinion gears on eBay just no ring gears. I’ve found one full set but it has damage and is pretty dang expensive for what it is.
Post a reply to: Pw50 qt50 setup
