Sterling, CT
6/16/2020 12:32pm
I am a newbie to the forum and to being in the dirt again after riding Harleys since the 80's. I have a 1997 CR125 Honda that has a 134cc big bore kit. Bought it last week, watched the PO start it and watched him ride around on it. I rode it and am comfortable with it but since I got it home, I can't start it. The PO says if it is flooded, the exhaust pipe gets fuel in it and that may be the problem. What is the normal start up procedure? No throttle, full choke, fuel off, then kick, then turn fuel on, kick again. Everything i've tried doesn't work. New plug (it does have spark), changed the gas. Very frustrating. Seems to have fuel coming out the exhaust manifold, so I'm taking the exhaust off today. Any other suggestions?
When the floats stick, all the excess fuel is supposed to run out of an overflow hose on the carb. But sometimes the fuel will go directly into the crankcase. Once that fills up, then it goes into the exhaust pipe.
So, if you have gas in the exhaust pipe, the crankcase is probably full also & your only chance at starting it would be the bump start method. Still, the gas in that crankcase has to go somewhere.
But better than that, would be remove the spark plug, turn the bike upside down (resting on handlebars/seat) & see if gas comes out of the spark plug hole. Probably best to have piston at the bottom of the stroke so gas can flow though the ports & not have to get past the ring. Anyway If gas comes out, wait until it stops coming out, turn bike back over, reinstall plug and hopefully you can start it with a few kicks.
It was probably 25 years ago that I learned this lesson well. A Buddys YZ250 filled up the pipe/crankcase. By pure luck on was on the non exhaust side as we pushed him to try it get it to start. It took a bit, but finally the thing belched a good cup full of gas out of the silencer (& right onto my other buddy) and started up. Smoked like crazy for a few minutes as the engine finally cycled through all the excess fuel. But it was fine after that.
Every since then, yes I turn the gas off if the bike sits for more than a few minutes.
Post a reply to: Newbie has a starting problem
