I have a 2016 ktm350sxf, i was just letting it idle for 2 min but went inside and forgot and let it idle for about 15 minutes, came back and was spitting coolant turned it off asap i saw what was going on what can happen?
Monk
12/14/2018 7:59pm
Could have overheated the motor... I would drain the coolant and see whats left and go from there. Worse case scenario you'll have to tear the motor down...
12/14/2018 8:04pm
Monk.....thanks so if all coolant is gone?
12/14/2018 8:05pm
What to do from where checking coolant and knowing how much was left?
Monk
12/14/2018 8:06pm
Personally, I would be tearing it down...
12/14/2018 8:15pm
So its not a add coolant and back at it thing? Its about 37 Degrees in texas and its first time it happens
Monk
12/14/2018 8:21pm
Well right now you might only have scoring. With a SOS pad and some contact cleaner on the cylinder you might be good, throw a new piston in and go moto.
Or you could add coolant and go moto and it could be perfect fine...
Or you could add coolant and the motor could scatter which could cost more to fix and also make for having a possible injury...
You could do a leak down as cheap insurance but it would still be hard to know the true condition of the motor...
12/14/2018 8:29pm
Your best bet to save the bike?
Paul_Pitzonka
Grand Terrace, CA, USA
12/14/2018 8:47pm
At this point there’s no saving it (if it’s hurt) as the damage would have occurred already so might as well add some coolant, start the bike first to see how/if it starts... was the bike making any odd noises or change in tone at idle prior to being shut off (other than coolant from the overflow)? Worst case as stated is disassembly of the engine...
CarlinoJoeVideo
Portland/Los Angeles, CA, USA
12/14/2018 9:44pm Edited Date/Time 12/14/2018 9:44pm
Is there still coolant left? The bike is probably fine. It was only 15 minutes and it’s almost freezing cold out.
I’d refill the radiator and see how she starts up and sounds. It’s not like you ran it with no oil for 15 minutes
GCBC
Pittsburgh, PA, USA
12/25/2018 8:15am
Id deff fill it up and run it hard so you can sleep easy or grenade it and know for sure.
Wink
King, NC, USA
12/26/2018 5:35am
As long as some coolant was still coming out I’m sure it’s fine,, put in new coolant and change oil for good measure and ride it
GCBC
Pittsburgh, PA, USA
12/30/2018 1:26pm
so what happened after you tried filling it up? thought about this last night what outcome was..
Cody427
Xenia, OH, USA
1/3/2019 11:25am
I have a 17' (same engine)and race hare scrambles. First GNCC at St. Clairsville (mudfest) mine got so hot it shut down. Radiator cap steaming, overflow, the works. Let it cool, started right up. First OXCR with fan same thing. Replaced all hoses, Engine Ice, Ethanol free gas. Just trying anything to keep this thing from grenading. Next race still overheating. What I found out is I need to go faster(more air) and stay out of roost blocking radiator braces. Thought this things toast. Tear down. Valves haven't moved and piston was barely worn 80hrs... Shocked. I've had mine to the point where its losing power at the top of a climb and spewing from every orifice, even shutting down. Fill it up, if its hurt you'll know. Pinging or lack of power. Its probably fine. Change the oil and look for metal shavings.
Post a reply to: Ktm350
