Upland, CA, USA
Does anyone know how to completly remove the adjuster screw asm from the fork cap asm.? The adj screw appears to have a collar around it that either threads into the cap or is pressed in or pressed n glued in??? I'm trying to remove them on the Compression and rebound caps on a pair of KYB SSS forks 2008 YZ250F. Any help would be appriciated. Trying to get them anodized and not sure if plugging the open end into the forks, since the adjuster side is sealed if it will make it thru the anodizing process and still function. Thanks!
shock adjuster may be different giving more access than the SSS caps. Just get the adjuster anodised also.
Post a reply to: KYB SSS Fork cap question
