KTM SXF 2017 SAG Help
elikoz
Hillside, NJ, USA
Hello guys
i understund that my riding sag on the bike is 110m and i want to change it to 105
in order to change it i need to remove the link and wp or no need to remove anything?
and i can just change it while its on the bike
much ty
IceMan446
Sacramento, CA, USA
8/1/2017 12:18pm Edited Date/Time 8/1/2017 12:19pm
Put the bike on the stand so the rear wheel is off the ground, get the correct size allen and loosen the lock ring at the top of the shock spring, turn the shock spring 2-3 turns tighter (to the left) and re-check the sag I think one turn is around 2mm in sag or pretty close.
Once its where you want it, tighten the lock ring. No need to do anything else.
aees
8/2/2017 1:18am
RTFM. This is described in the manual that you got with the bike or can download from KTM website...
1HRCrider
Newark, CA, USA
8/2/2017 3:09am
If turning to left, wouldn't that be loosening?
opyguy
Boston, MA, USA
8/2/2017 4:30am
Clockwise-tighten
Counterclockwise- loosen
8/2/2017 5:41pm
Yes! Much ty! What do you want repeated to you today?
Post a reply to: KTM SXF 2017 SAG Help
