Hernando, MS, USA
Hoping some other current / former mini dads will be able to help guide me here as I've been left scratching my head.
My son moved up to a '22 KTM 50sx mini this winter and it's been going well. On Sunday, we went to a track to practice. He did one ~15 minute session with no issue, then took a break while I went out. About ~5 minutes into his next moto, the rear wheel locked up solid. I think, "great, the clutch went out " and carry it back to the truck to put on his stand.
Fast forward about 15-20 minutes - after I've periodically messed with it and the wheel still being stuck - my 5 year old grabs and spins the rear wheel. It free wheels almost like the front would, if spun. Ok, weird, but I think it's still the clutch. Start it up to check it and the rear wheel doesn't spin. He's done for the day and sticks it out while I ride.
We get home and I start washing all the bikes and gear. Something tells me to check it one more time. Fire the bike up and it works like normal. Now, I'm stumped.
I've taken his bike apart, inspecting everything, and can't see any wear in the clutch parts (plates, basket, etc.), no typical burnt smells, etc.
Has anyone else ran into a similar issue and, if so, what was the cause?
FWIW - I change the oil after every ride day with Motorex, run the stock 9 click clutch setting and am getting an entire clutch pack to have as a back up moving forward.
If you’re racing local and not worrying about being AMA legal I wouldn’t wast a penny on the stock clutch and would go straight to the IRP Triple Grip clutch. Light years better than the stock POS on those bikes. If you’re racing AMA and trying to make Loretta’s or Mammoth or whatever, sell the KTM and buy a Cobra immediately (which also have a ton of problems).
Stock a spare stator too…
Good luck my dude and praying you get thru to the 65’s soon. You’ll be a lot happier at the track when you’re done with 50’s LOL….
That's actually something that I checked at the track and put a Nihilo case saver on for that reason. But, not to say that I simply didn't see the obstruction in the chain guide or it fell out when I was getting it back.
I'll pick up an extra stator and probably go the IRP route for sure.
Other takeaway for me, I guess, is to always bring his PW too as a back up to salvage riding days for him.
Thinking about your issue, the clutch could’ve got so hot it expanded and locked it up. Seemed like after it sat or cooled down it free’d up.
Hey, new to this.. what made you shift to the B&W trick shift? I just picked up one of these bikes with an IRP clutch, but I’m in canada and IRP don’t ship liquids to Canada. - would you still recommend the B&W?
The oil from IRP is good but very expensive. I’m pretty sure it’s a clear ATF he sources from somewhere and labels it. I had heard about guys using the B&W and was able to get a gallon for the same price as a quart of the other stuff. Seemed to hold up to a lot of abuse, had good bite and ran cool as well. Everyone on 50’s in my area started using it and we didn’t see any oil related failures.
Thank you 🙏
Post a reply to: KTM 50sx mini help
