ES
5/1/2022 12:30am
Hi, I recently bought a Beta 4t 390 from 2020. I ride mainly enduro, and coming from a 2019 GasGas with Kayaba CC, these bike is quite soft.
The beta has the split OC sachs forks (similar to the Xplor from WP). The forks are fantastic in the slow single trails and rocky sections but they have way too little damping in low speed compression. The clicks do almost nothing.
I want to try with the stock shims before buying an aftermarkit upgrade kit. This is my first time shuffling shims althought I think I have a slight idea from reading in thumpertalk.
My stock settings in the base valve are as follows:
From the piston
2 - 18 × 0,15
1- 22 x 0,10
1 - 25 × 0,10
1 - 18× 0,10
1 - 25 x 0,10
1 - 20 × 0,10
1 - 18 × 0,10
1 - 16 × 0,10
1 - 14 × 0,10
1 - 12 × 0,10
1 - 10 × 0,30
What do you sugest (I have no extra shims) to get more low speed damping (I am happy with high speed impacts).
Thanks
From the piston
2 - 18 × 0,15
1- 22 x 0,10
1 - 25 × 0,10
1 - 18× 0,10
1 - 25 x 0,10
1 - 20 × 0,10
1 - 18 × 0,10
1 - 16 × 0,10
1 - 14 × 0,10
1 - 12 × 0,10
1 - 10 × 0,30
Thanks
Those 18x0.15 are bleed shims (don't know if that is the right name), I mean, they do not fully cover the piston ports. I know I should put a wider shim there but don't know which one should I use.
*Edit* Using what is there you could valve it to be more progressive without needing any extra shims or getting rid of any.
Free shipping: VITALMX
And yes what I want exactly is more hold up. I get excessive diving when braking hard
Tomorrow I hopefully have some time and will try what you suggested as it was actually mi idea, I just was not sure what to do with the removed shim... I'll put it at the end as suggested.
Thanks for the help 👍🏼
I opened my forks and seems like they had already been revalved by the previous owner. The valving I found had nothing to do with the stock one... This I what I found
I changed the crossover shim for the second to last shim next to the clamp. Took 25cl of the 7.5w oil and replaced it with 25cl of 20w oil... Yesterday I went for a ride with a wide range of terrains and speed, and so far happy with the change.... And this allowed to get the clicks to middle of the range (I had them ranging from 3 to 6 from close before the changes).
So all good. Thanks
Simply put these forks have a hardware problem. The design is cheap and ineffective compared to other systems. No real external compression adjustment. It will blow though and spike. It needs added parts or better yet a complete replacement cartridge.
I have some things we do to the shock to make it much better as well.
Post a reply to: Help with a revalve
