Front Brake Swap
superkook
El Dorado Hills, CA, USA
I have an 89 YZ250 with terrible brakes. The stock master cylinder limits the adjustability of the lever. Is it possible to swap to a modern master or would I need to replace the caliper as well? Any advice or suggestions appreciated.
R VanKamp77
Portland, TN, USA
10/29/2022 10:58pm
superkook wrote:
I have an 89 YZ250 with terrible brakes. The stock master cylinder limits the adjustability of the lever. Is it possible to swap to a modern...
If the brake line will fit, it will work.
If the brake line wont fit, get a correct brake line. Then it will work.
All the master cylinder is doing is generating pressure for the caliper. Your question is akin to asking if a certain brand of air pump will work on a basketball.
Post a reply to: Front Brake Swap
