Lynnwood, WA
9/3/2020 8:59am
I have brand new brake lines on my RM project bike, brand new banjo bolts, and brand new copper crush washers. They are dripping around the sealing surface between the line and the caliper.
I had them locked down hard and it still wouldn’t seal. Any suggestions? Should I do any prep to the surface areas? I just had the calipers ceramic coated
Only thing i can say is use quality parts from galfer or oem. Did you try your old lines?
Free shipping: VITALMX
I’m running out of ideas. I guess the next step is to give a name brand line a try 🤷🏻♂️
Also looking at the pics again, the coppers look like they could be too big, in a hydraulic application the copper should be about the O.D. of the banjo bolt.
I am sure you can get what you have to work without dumping more dough at it.
Thanks for all the suggestions guys!
Post a reply to: Brake lines leaking
